Catia V5R19 -- Drafting tangent maseurement 1
CAD2015
Computer
Jan 21, 2006
2,048
Please have a look at the attachement.
I need to create a vertical dimension between the center of the cilinder (B) and the upper arc (A).
How could I get the tangent point on the upper arc?
Thanks!
MZ7DYJ
it is easier with the option turn ON in Tools/ Options / Mechanical Design / Drafting // Manipulators : Move dimension leader ON
download.aspx
Then when you create your dimension, move the mouse horizontally, this will give you vertical dimension:
download.aspx
Have the value in the proper place, then press CTRL, this will lock the dimension line and value position but you can move the mouse to the yellow square (the manipulator):
download.aspx
With CTRL presses move the yellow Manipulator to the position #4 :
download.aspx
Voila!
Eric N.
