The short answer is V5R21 is not supported by Dassault, meaning most probably if you want to try to use it on Win 10 64 bit you will have some problems.
Even more, you can notice on that link which releases are under support if you are a usual customer.
If you really need to work with R21 then you need to downgrade your Win 10 to Win 7.
