CATIA V6 Plane repitition 1
Lars26B
Aerospace
Aug 5, 2015
8
Hi!
I'm looking for a script or macro which allows me to create planes on all points and a curve i have made.
I have a excel file with xyz coordinates which I import into Catia (V6 GSD) creating a geometrical set called "GeometryFromExcel". This geometrical set contains all points and creates a spline through all these points.
I want to create planes on every single point regardless of its name (example: Point.1 or point.50 shouldnt matter). Using the "normal to curve" function of planes.
The amount of points may vary.
Hope you guys can help out!
Cheers
do you import excel points into V6 with a script?
Eric N.
I Do. I use the script which is already in Catia. I believe its called : GSD_PointSplineLoftfromExcel.xls
why don't you modify it to create the plane?
Eric N.
So basically i want to have a set of planes all offset from the XY plane which can be made using a txt file or excel file.
I've tried to record my own macro but i do not know how to get it to loop...
As written above, I do have a way to input points and a line using a excel table.. just not the planes yet.
Code:
Sub CATMain()
Dim editor1 As Editor
Set editor1 = CATIA.ActiveEditor
Dim part1 As Part
Set part1 = editor1.ActiveObject
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("GeometryFromExcel")
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapeSpline1 As HybridShapeSpline
Set hybridShapeSpline1 = hybridShapes1.Item("Spline.1")
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromObject(hybridShapeSpline1)
Dim hybridShapePointCoord1 As HybridShapePointCoord
Set hybridShapePointCoord1 = hybridShapes1.Item("Point.1")
Dim reference2 As Reference
Set reference2 = part1.CreateReferenceFromObject(hybridShapePointCoord1)
Dim hybridShapePlaneNormal1 As HybridShapePlaneNormal
Set hybridShapePlaneNormal1 = hybridShapeFactory1.AddNewPlaneNormal(reference1, reference2)
hybridBody1.AppendHybridShape hybridShapePlaneNormal1
part1.InWorkObject = hybridShapePlaneNormal1
part1.Update
Dim settingControllers1 As SettingControllers
Set settingControllers1 = CATIA.SettingControllers
Dim settingRepository1 As SettingRepository
Set settingRepository1 = settingControllers1.Item("VPMEditorDisplay")
boolean1 = settingRepository1.GetAttr("Mask_LockEditability")
End Sub
the loop should be around
you can loop all element in hybridShapes1 and test if you have a point
Code:
for each oShape in hybridShapes1
 if typename(oShape) = "Point" then
Set hybridShapePointCoord1 = oShape
next
that should take all points in that geometrical set
Eric N.
I now have below code. It doesnt give an error but doesnt do anything either. I'm sorry for being such a newbie at scripting..
Code:
Sub CATMain()
Dim part1 As Part
[b]For Each oShape In hybridShapes1
If TypeName(oShape) = "Point" Then
[/b]
part1.Update
[b]End If
Next[/b]
End Sub
insert
Code:
MsgBox (TypeName(oShape))
before
Code:
this will help you find the type of point
once you have it replace
Code:
If TypeName(oShape) = "[u]Point[/u]" Then
with the proper Type.
do this with a small number of points in your file.
Eric N.
