CATIA VBA Drafting Workbench
pgm575
Aerospace
Does anyone know the code to run the Symmetry command on all geometry in a DXF? I already have code to open the DXFs and to select all 2D lines with a search in the Drawing object but haven't quite figured out the Symmetry portion yet; the Automation help for CATIA (V5 R23) doesn't really seem to list it.
Thanks all!
That command appears to be running but the code doesn't wait after the command call, it just moves on. It may have to do with the fact that I'm running a
Code:
selection.Search "CATDrwSearch.2DLine, all"
right before the Symmetry command, since I think that search will also select the "VDirection/AbsoluteAxis/Main View" and "HDirection" lines; effectively, this would leave no geometry available to be symmetrical about.
Is there a declaration to only select simple 2D lines and not the axis lines?
I was able to step through the code and the problem seems to be that I can't select the Vertical or Horizontal axis. If I stop the code right there and just hand select the vertical axis, the symmetry command completes just fine.
Do you know what the search command is for the axis itself? I tried "2DAxis, VDirection" and "2DLine, VDirection" but no luck so far.
The command is using a selection, which can be a line, a construction line or something else. Key word is selection, so you have to indicate that line.
If you create that line (symmetry) in your code then is much easier because you can change the name with a specific one (like mysymmline for example) and then you can use a search by name.
Fernando
- Romania
- EU
Alright, I'm real close here. I was able to run the Symmetry command with no error before but without selecting the axis (so the code would move on without completing the Symmetry command because I close the file), and I was also able to create the line without running the Symmetry command. If I combine the code, however, I get the error Command unavailable: when I reach the "CATIA.StartCommand (Symmetry)" line. Here's what the code looks like:
Code:
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim DrwSht As DrawingSheet
Set DrwSht = drawingDocument1.Sheets.ActiveSheet
Dim DrwView As DrawingView
Set DrwView = DrwSht.Views.ActiveView
Dim fact As Factory2D
Set fact = DrwView.Factory2D
Dim symLine As Line2D
Set symLine = fact.CreateLine(0#, 0#, 0#, 5#)
Dim selection3 As Selection
Set selection3 = drawingDocument1.Selection
selection3.Search "CATDrwSearch.2DLine,all"
Dim selection4 As Selection
Set selection4 = drawingDocument1.Selection
selection4.Search "CATDrwSearch.2DLine,symLine"
CATIA.ActiveDocument.Selection.Clear
Just can't quite figure out the last bit here. I tried moving the Symmetry command up and down in the code but to no avail. Do I need to reactivate the sheet or something, like in Excel?
Is CATIA.StartCommand "Symmetry" . But still, I would try to use something like bellow (Application. Wait or Sleep). In vba you can also sendkeys to the input line . You need the wait time to pick the symmetry line - here you can find in this forum or on Google different techniques.
CATIA.RefreshDisplay = True
AppActivate "CATIA V5"
SendKeys "c:Symmetry" + Chr(13), True
Application.Wait Now + TimeValue("00:00:10")
By the way, if you want to change the name of the line you have to
symLine.Name = "my_symLine"
Fernando
- Romania
- EU
Sorry, was out traveling for a week.
Both
Code:
Application.Wait
and
Code:
CATIA.Application.Wait
throw up Object Required errors. Trying to figure this out now.
I've added as many libraries as I can but the "Wait" method is just not available to the "Application" object. Kind of scratching my head on this, since I see this particular line of code all over the place.
That's not really helpful, least of which because I already know how to use Google. All I've found on all these different forums is the same line of code repeated over and over, and a MS article that states that the Application object is part of the generic VBA library reference which I've already selected.
Either way, I made a loop delay Sub instead, and the 10 second pause doesn't help. The command still isn't completing.
When I figure out what's going on, I'll post the code back here.
Code:
Sub CATMain()
MsgBox "You have 10 seconds to pick elements to create their symmetry and the symmetry line. Look in lower left corner of CATIA window for instructions"
On Error Resume Next
Set objCATIA = GetObject(, "CATIA.Application")
Set symLine = fact.CreateLine(0, 0, 0, 5)
Dim time1, time2
time1 = Now
time2 = Now + TimeValue("0:00:10")
    Do Until time1 >= time2
        DoEvents
        time1 = Now()
    Loop
MsgBox "Time passed 10 sec"
End Sub
Fernando
- Romania
- EU
Sorry, I understand the confusion now.
I'm trying make this automatic, no user input. I have 1000's of DXFs to mirror and can't have someone sitting there clicking. Thus the attempt at selecting the "symLine" after selecting all the other 2D geometry.
I'll keep working on forcing this selection.
Alright, I made it work. Here's the code:
Code:
selection3.Search "Drafting.Polyline,all"
Pause (1)
Pause (1)
Pause (1)
Dim selection5 As Selection
Set selection5 = drawingDocument1.Selection
selection5.Search "CATDrwSearch.DrwText,all"
Pause (1)
Pause (1)
selection4.Delete
The text doesn't seem to mirror properly (the mirrored text is shifted slightly from its original position), indicating that there is some sort of offset applied to the text. That's the last bit I'll need to figure out.
The anchor position was getting reset, so I just added this:
Code:
For i = 1 To DrwView.Texts.Count
    DrwView.Texts.Item(i).AnchorPosition = catMiddleRight
Next
And everything works now. Thanks for the help!
