CATIA VBA Macro to Hide Parts
JV03
Aerospace
In need of some programming help.
I'm trying to create a macro to hide all hardware from an assembly. (i.e. NAS*, SL*, etc.) The problem I am having is that if a sketch within a sub-assy has the hole feature name SLXXX the macro recognizes that as an instance and hides the sketch, therefore hiding the entire sub-assy. Is there any way around this?
Below is the code I have so far.
Sub HideHardware()
'Finding and hiding all hardware
MsgBox ("This Macro will hide all common hardware: SL*, NAS*, MS*, TYE*, AN*, CCR*"), vbOKOnly
Set productDocument1 = CATIA.ActiveDocument
Set Selection1 = productDocument1.Selection
Selection1.Search "Name = NAS*+AN*+MS*+TYE*+SL*+CCR*, sel"
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetShow catVisPropertyNoShowAttr
End Sub
Any help would be much appreciated.
You can loop the selection and remove the item if it's not a Part.
The following code do the job
Code:
Sub HideHardware()
 Dim itemInSelection As Integer
 itemInSelection = Selection1.Count
 U = 1
 While U <= itemInSelection
    Set checkItem = Selection1.Item(U).Value
    If TypeName(checkItem) <> "Part" Then
        Selection1.Remove (U)
        itemInSelection = itemInSelection - 1
        U = U - 1
    End If
    U = U + 1
 Wend
 End Sub
Eric N.
faster is to make another search in the selection after the first one
Code:
Selection1.Search "Type = Part, sel"
Eric N.
or in 1 shot
Code:
Selection1.Search "(( Name = NAS*+AN*+MS*+TYE*+SL*+CCR*)&Type = Part), sel"
Eric N.
Thanks for your input. Works perfectly.
