CATPart Conversion
JRMorton
11
I need to convert a CATPart from V5-6R2013 to V5R20. I accidentally saved a V5R20 file using V5-6R2013. A customer can only view and work with the CATPart using V5R20. Thanks to anybody that can help.
export to step
you'll never get the full parametric part in r20 (unless you do the work again)
Eric N.
Is there a readily available method to determine the version of a CATIA document?
Right-click your part in Windows and Open With > WordPad.
Ctrl+F to search and type in catiav5 and the first result should show you the version.
