pmartinson
- Nov 22, 2010
- 2
First of all: I realize this a bit outside of the main scope of the Bearing design Forum, but couldn't find one that was more fitting. Suggestions are welcome. Now then, onto the good stuff:
We're developing a belt-driven mobile robot chassis, and have run into some problems with one of the prototypes.
There are a total of 6 drive axles which the wheels are coupled to, with 3 per side. Each side is coupled by a pair of timing belts, and a 3rd belt transfers power from the motor & gearbox to the rearmost axle on either side.
We're experiencing a problem in the rearmost axle on 1 side.
When running in the forward direction, the shaft starts to translate axially towards the outside of the chassis. When running in reverse, the shaft translates in the opposite direction.
The axial forces are enough to deflect the plate meant to constrain it axially, and a quick analytical calc got us 260 lbs of force applied at the shaft's centre to cause the deflecction we've seen. At this amount of translation, the shaft is no longer making contact across the full length of the bearing's inner race (in extreme cases it was only making contact with 1/2 the length), and this is causing abrasion inside the bearing, and visible wear on the inner race as well as the axle.
We believe that this is a function of the high tension in the belts, which may cause the shaft to deflect slightly. This deflection results in an axial component of the tension. We have no tools on-hand to accurately measure for shaft misalignment.
If anyone has some suggestions for ways of measuring the misalignment, or some possible other causes for the misalignment or the translation itself, they'd be greatly appreciated.
Thanks,
Patrick
Thanks,
Patrick
