AJAvery
- Aug 27, 2007
- 1
We are having issues with caustic injection into 30,000 gallon pH adjust waste tanks. The "injection" is done with a control valve feeding a 1" PVC line into the top of the tank. The issue we are experiencing is crytallization of the casutic in and around the 1" pipe. The pipe ends ~5 feet above water line. The tank is closed but does have exhaust.
1. What causes the crystallization?
2. What is the best method to inject cuastic soda into a water solution?
Thanks in advance,
Andy
Thanks in advance,
Andy
