OilToil
Chemical
- Oct 21, 2009
- 15
Hello all,
We have a remote gas sales facility that utilizes a caustic wash system, and apparently, intermittently the entire liquid content of the caustic wash vessels are carried out to the sales pipeline.
The system is configured as shown in the attached drawing, basically 2 vertical vessels operating at the same time in parallel, 20 feet tall, 80" diameter, 10 ft of liquid level in each. The gas inlet is on the bottom with a 6" diameter sparger with thirty six, 1" diameter, holes down the length of the sparger, holes alternating at 6 o'clock, 7 o'clock and 5 o'clock positions. There is a splash plate under the overhead vapor outlet, but no mist extractor.
The feed gas total is 3 MMSCFD, 70F, 30 PSIG, coming in 6" lines.
This system currently has no downstream scrubber vessel, just straight to a sales line. The treating liquid is not continuously regenerated, it is switched out and a new batch loaded when needed.
My questions are:
How to determine if the sizing of these vessels is appropriate for the current gas rates? We have none of the original design information. The closest thing I can think of is to check what vertical 2 phase flow regime we are in (but then the liquid is batch, not flowing), or a column tray flooding calculation, but I'm not sure if those correlations will work with 10 ft of liquid head. In any case, I don't think 1.5 MMSCFD through an 80" vessel is anywhere near enough velocity to entrain that much liquid?
Once I know what I should be checking for steady state design, the operations folks have hinted that the carry over problem may be more likely to occur after the field has been shut in and pressured up for a time. If the field were to pressure up to ~150 PSI and then the sparger inlet valve cranked open, well maybe that could carry some liquid out, and I will check that case too.
Is operating two of these in parallel stable? It seems to me that as soon as one vessel is fluidized, that vessel will take all the flow?
The holes on the sparger seem pretty large, where can I find design guidelines for spargers?
Suggestions to improve the design? A downstream scrubber would at least mitigate the issue and calm down the guys receiving 5000 gallons of chemical at their plant inlet unexpectedly...
Appreciate any insight you may have
My questions are:
