Hi guys,
I am facing a certain condition in which I am unable to acertain the cause of loss of suction & reduction of flow and discharge pressure of a pump abruptly which leads to cavitation.
The pump is not showing any symptoms which conclude for any wear & tear in pump.
Other wise the pump is running normally if restarted by procedure.
The person operating the pump says,when during cavitation if the pump is filled with flushing medium for hrs together then it again regain its suction & normality.
The pump is also running in its design temperature range.The suction strainers & pipes are also clean.
Except for NPSHA,NPSHR calulations & theories what are the other possibility of this cavitation and how can they be solved???????
Kindly, help me ASAP.
