Hi, I am a new CDEGS user and I am trying to design a 3-core cable. I am using define -> cable type to enter cable properties in SESCAD. Although induced sheath currents are calculated perfectly and the results can be easily found in the output file or by using SesResultViewer , I am not sure how to "see" the results for Voltage at a single point (sheath voltage drive end and earth end or phase voltage at drive end and earth end) and voltage drop.
My questions are:
Should I use Metal to Soil - GPR of Metal - GPD with the correct reference ?
Do I have to define ground voltage - 0 volt somehow in my design ?
My questions are:
