Cell Activation After Sort 1
thunderkid
Military
Jun 12, 2008
I am using VBA codes to sort hundred of rows on a sheet. However, after the sort I have to scroll down to the last row to add a new row. How do I activate (if that is the correct term) on the cell after the last row. I have tried the following:
Range(Selection, Selection.End(xlDown)).Offset(1,0).Activate
This code highlights the column of the active cell, but the active cell is at the uppermost cell in the selected column.
Any hints would be appreciated.
Couldn't you just select the bottom-most row (65536) in the column, and do a xlUp?
Range("A65536").Select
Selection.End(xlUp).Select
That will select the last element in the the column.
melone,
Your solution worked perfectly! Working from the bottom up approaches the task from a different perspective. Thanks again. Have a star!
Thunderkid
