Centre of Pressure & Drag of Rocket at Supersonic Speeds
aristox
5
I am new to the subject of Aerodynamics and would like to know if there is any direct method to calculate (or obtain graph) the CP and Drag of a simple rocket with a ogive nose and 4 fins. I know that u cannot use Barrowmans method at Supersonic speeds, and I do not have any access to Hoerners book. (im from India). I know that, from Hans Olaf Toft's software "AeroLab" (D.A.R.K.)that Shape, Dimensions, surface roughness, no & position of fins & lugs, Reynolds no, mach no are the required input parameters. what I dont know is how he obtained the CP at supersonic speeds, and the graph of Drag v/s Mach no. I would hope that someone could elaborate with OPTIMAL (not empirical) relations on how to do so.
Thanx.
Hi, kindly recommend any supplier that supplies instrument for force balance at wind tunnel. Thanks.
