centrifugal pump efficiency
hhjlep
8
I need to estimate an efficiency of a centrifugal pump, but do not have any specifications. This is what I know:
Single stage centrifugal pump
Static head: 100m
Motor power: 200 kW
Water quality: Poor. Water is pumped from the bottom of a gold mine. It is not slurry, but it does contain rock particles.
Given the limited information above, what efficiency can I expect? Rough figure such as 30%, or 50% will be sufficient.
Given: P = 200 watts = 8850.7 ft.lb/min
H = 100 meters = 328 ft. head.
assume water is 62.4 lb/ft^3
ft.lb/min (power)= 8850.7 = ft^3/min (flow) x 62.4 x 328 ft/E (efficiency)
8850.7 = 62.4 x flow x 328/E
E = 62.4 x flow x 328/8850.7 = 2.312 x flow
Sorry. You have 1 equation, 2 unknows. No unique solution.
The efficiency for the pumps, which should be hard metal slurry pumps would be round 50%. Using 200kW flow rate would be somewhere round 100l/s. fairly rought and ready but so is your enquiry.
Is it possible to measure the flow rate and motor amps? These with the static head would allow the efficiency to be calculated.
Easiest thing to do is go back to the pump vendor and ask for a sales curve for that pump model and running speed.
If you really want to do some calcs and "play around" (that's what I call it) with some numbers go look at the pump name plate.
You can measure motor amps to give you and idea where you're at on % load relative to motor FLA. In pump applications typically motors are sized so the max BHP (and FLA) coincides with ~120% of rated flow. If you're just under motor FLA then you can assume you're at or near rated flow (name plate flow). Use that flow and head to calculate a Specific Speed (not pump RPM... Google it if you don't understand) for that impeller. Use that specific speed number to search online for a pump OEM's sales curve for a similar pump design and application. Compare the head/flow they give for your impeller diameter (also on the name plate) to your "assumed" head/flow.
efficiency=(H x Q x Specific Gravity) / (3960 x BHp)
units:ft, gpm, Hp
You should measure the flow rate, and the BHp at this flow (by measuring the amper)and specific gravity of pumped fluid and then simply use above equation.
Reza
rshayesteh,
In this case I think he would get a divide by zero error.
"I'm all in favor of keeping dangerous weapons out of the hands of fools. Let's start with typewriters."
- Frank Lloyd Wright (1868-1959)
