Marcus Gatenby
Agricultural
Hoping somebody can steer me in a direction
Centrifugal pump controlled by VSD, control loop increases/decreases speed dependent on end of process line pressure (min 2.0 bar)
Higher than sustainable amperage only occurs when operating specific products (higher viscosity) although not every time
Process line operates at the same flow (21.5 m3/hour) at all times, amperage tends to increase as time (40 hour runs) increases
Specific products can be manipulated which eliminates amperage issue, a 1% increase in fat from run start eliminates issue
Impellor distance from volute "back plate" has been set to maximum (20.0mm), amperage issue slightly worse from this change
NPSHa is above pumps minimum requirement by approximately 0.1m, pump does have a 90 degree bend 4 pipe diameters away from entry
Pump operates to the far left of pump curve, pump flow at best BEP approximately 100 m3/hour, pump operates at 21.5 m3/hour
Even when pump operates with low amperage motor/pump housing has been seen shaking/vibrating although no cavitation can be heard
Pump operates with seal water, the mechanical seal/impellor do not appear to suffer infant syndrome as in same parts for 3 years
Thanks for taking the time to read & think this out, I appreciate it.
Feedback from replies:
JohnGP - Yes NPSHa is very low, pump probably is cavitating although I had not thought more about this due to lack of noise
QualityTime - Cannot throttle discharge, 4 - It could be possible that air is entrained during tank swap events, pipe sounds full
Littleinch - Agree NPSH not good, pump was selected for its head potential, operates at 80%, amperage exceeding maximum = unsustainable
DubMac - I will look into viscosity correction, the difference from good operating to poor in viscosity terms is approximately 15cP
Artisi - Measurement of heights above pump centreline, pipe line leading to measured and friction factors calculated, no gauges yet
