Is it acceptable to use centrifugal pumps for discharging into relatively short mains that are initially empty? The kind of thing used for large drainage pumps that simply lift and dump the flow over a relatively low static head without non return valves.
I know that normally one would think of using an axial or mixed flow for this duty, however the head is around 12m and in the range for a centrifugal pump.
Two areas of concern with using centrifugals are:
1) Pumping into an empty main. We would be using soft starts therefore the max flow would not be instantaneous, but ramped up. Would this allow for no head starting in particular problems with being off the curve? If not how would an axial or mixed flow pump cope better with this?
2) Backflow – I cant see any special problem particular to centrifugal pumps with this, as long as the impellor is secured properly.
Any comments much appreciated.
Sow
Sow
