esperantes
- Dec 11, 2020
- 25
Hello Pump Experts,
We have an installation where a 160 k W 2900 rpm 10 bar centrifugal pump pumps river water from a tank to a centre pivot used for irrigation purposes. The discharge valve is throttled to maintain 6-7 bar to the center pivot. This pump was operating fine this way until it was replaced by a 160 k W 2900 RPM 12 bar centrifugal pump. It is worth mentioning that a 12 bar rated pump was selected because in some rare occasions we require to pump river water to a very distant location. The pump was replaced because both impeller and casing were worn after several years of operation. The volute casing, impeller and shaft of the new pump are made of stainless steel. The shaft sealing is packed gland. After one week of operation, the two bearings of the new pump failed. We were told by the pump supplier that the throttling of the discharge valve caused the bearings to fail. We were told to trim the impeller diameter to 260 mm to achieve 6 bar as per the pump curve. We did so and put back the pump into operation. The discharge valve was kept fully open and the discharge pressure was 6 bar but the bearings failed again after 12 hours of operation. What could cause the bearings to fail? The pump curve and drawings are attached.
Esperantes
Esperantes
