Ceramic Bearings
Sofistioelevib
Industrial
Jun 24, 2015
95
0
0
IT
Hello guys,
what do you think about ceramic Bearings frequencies? The fault frequencies are the same as normal bearing?
What frequencies are for HBC 7019
Thank you
Thank you Strong[machinegun]
Normally the first stage for bearing problem show defect sidebands around natural frequency of the bearing.
I suppose the Natural frequency of this ceramic bearing will be different from steel one.
Do you have any experiencies about this HBC 7019 natural frequency will be in the spectrum?
Roberto
This is my first experience with ceramic bearing and i think no differencies or big differencies are between common bearing.
Due to my inexperience i only would like to know if i can go into diagnostic error using the standard vibration analisys methodology.
Roberto
I have to acquire measurements for the first time on a turbine fan,
so I wanted to first have information on ceramic bearings.
The bearing supports are inside the machine pipe,
therefore not being able to acquire measurements from outside the duct,
I will use the cable already installed that goes to DCS to acquire data, if compatible!
Claudio
Hello Claudio,
i suppose your bearing is anyway near to external of duct structure.
Where the sensor installed?
Is close to bearing?
The data goes to DCS is conditioned to 4-20 ma or it is a real voltage coming out from sensor?
Give more detailed informations
Thnak you
Be aware that you cannot do waveform/spectrum analysis from a 4-20 ma current signal!! If the accelerometer has an AC output or is connected to a transmitter with AC output, then that is where spectrum and waveform measurements can be made.
Walt
Walt,
i agree with you about you can acquire data on 4-20 mA but i think using the Voltage coming out from sensor it is better.
First because (but this could be opinable) 4-20 ma have less speed change respect the mV.
Secondly because for a very big increment the 4-20 mA sensor could go into saturation instead of Voltage that normally have a very big high spot G's value
Furthermore the S/N ratio (on the sensor) is bigger than 4-20 mA because ther are no conversion (all sensor pickup convert signal into a tension before everything)
@Strong: this unit is the same for the post with motor @9600RPM
@Strong....the gunman was only for the "Strong" [bigsmile]
For this reason (driving @160Hz) probably the bearing are in ceramic material (for the eddy currents generated).
Another questions is consequent:
The ceramic balls prevent eddy current but at this speed is not too dangerous? i'm not experienced but i think at this speed when bearing fault start degenerate in a very few time, isn't it?​
Could you share your experienced in ceramic bearing fault?
thank you
