Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
What are you brazing to what in this case? No braze that I know of will adhere to these refractory materials...
The trick with ceramics is to keep them continuously in compression. Consider heating the outer sheath metal and shrinking it onto the ceramic core.
could you glue it in with this stuff?
{like high temp ceramic loctite)
We do this regularly see:
You might also look at flamespraying a metal coating onto the ceramic.
