Very simple circuit - Cetop 3 valve on a single manifold with PRV, feeding a reversible gear motor.
Whichever solenoid is activated, the motor turns in the same direction.
If I swap the hoses over, the motor does change direction, (although the valve still does not reverse the flow when the opposite coil is activated).
I have tried a replacement valve (of different brand) and I get the same result.
(A hydraulic supplier, clutching at straws, suggested perhaps I may have received a valve that was mislabelled, but after replacing it and getting the same results, I'm ruling this out now as the cause)
Cetop valve is 3-position, all ports open in neutral position.
Any ideas?
Any ideas?
