materazzo
- Jan 15, 2017
- 1
Hi All,
I have been contacted for technical advice on a coastal/beach development in Dubai (UAE, Middle East). The existing top coating of the external steelwork has been affected by the "chalking" phenomenon (see attached pictures).
The paint system has been specified by the Client as follows:
- Preparation, Grit bast clean to BS 7079,
- Primer. Zinc-rich Epoxy primer (60 microns DFT min)
- Build and finish coats. High build epoxy micaceous iron oxide (MIO) (min 200mirons DFT)
- Finish coat: Acrylic Polyurethane (60 microns DFT)
Do you have any experience with "chalking"? Causes and mitigation measures? Do you believe the specified paint specs mentioned above are suitable to an aggressive beach environment exposed to direct sunlight? if not, why?
Simone
Simone
