JDeWick
- May 2, 2024
- 6
Can the catch basin of an underground chamber system be used as the overflow (primary outlet) of the chamber system?
We designed a simple low volume stormwater detention system using the HydroCAD Chamber Wizard. It's 24" pipe and stone in well drained soils and holds the entire volume of the design storm with the help of exfiltration. The primary overflow/outlet device is the catch basin feeding the chambers. Someone is asking if we need another outlet device. I don't think so, but want hear if there is a problem with it and if there are other recommendations.
