Change Body Name automatically
Lea75
51
ES
Hello everyone.
I need to change the PartBody name automatically according to specific parameter.
For example, if a change a Diameter to 12mm, the PartBody should be renamed to "Bushing Ø12"
Is it possible to do so without using macros? Maybe a rule? Any suggestion?
Hope you can help me.
Thank you in advance. Regards
Great! Thank you
Can you explain it a little more?
I don't know how to do it
OK, I've already done with a reaction.
I didn't know the command but I finally got it.
This is the command, it is simple... but this is the problem of the ignorance ;)
Partbody.Name="TEXT"+Parameter
Thank you for the tip
