Parts in Assembly are showing up empty (no body) in assembly tree.
tectactoe
Quick precursor: Had no issues previously, recently got a new computer at my work and am running into this problem, so it has something to do with that. Not sure what. I've asked colleagues to verify they are not having this issue and sure enough, it's only me.
When I open a CATProduct, the assembly loads and appears fine. All parts are visualized, everything appears as it should.
Yet when I try to expand the tree for some of the parts, the body that would typically show up under that node is simply gone.
See below: The body for this part is missing, and the publications are all broken:
For parts without publications, the node doesn't even open! You click the "+" button and the + button simply disappears:
Furthermore, everything looks fine from the Desk side of things, the parts that aren't showing up in the tree appear to be loaded properly in the Desk:
If I close the CATProduct and open the CATParts individually, they are fine.
Any idea what the issue here could be???
Thank you.
you have loaded the visualisation part--.cgr file. Switch do design mode, that will load in the geometry, and resolve/define the publications
regards,
LWolf
