Extract Surface from another part in assembly
MShetty
Automotive
Feb 27, 2020
10
I am trying to extract a face from a part in an assembly without doing any changes to the original part. Manually, the workflow will look like this.
1. Activate the part where I want the extract
2. Select Create Datum option
3. Pre-Select the Face I am trying to extract
3. Create Extract
End Result looks like this
This way, an isolated extract of a face from Part.1 will be added inside Part.2.
But I am unable to achieve this. I tried to create reference from BREP of the selected face in Part.1 and then create an extract in Part.2, but it fails.
Any idea how I can achieve this via VBA?
What I have managed to do so far:
Code:
Sub CATMain()
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Set sel = CATIA.ActiveDocument.Selection
Set selFace = sel.Item(1).Value             'Preselect the face
Dim partDocument1 As PartDocument
Set partDocument1 = documents1.Item("1.CATPart")
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim assemble1 As Assemble
Set assemble1 = shapes1.Item("Assemble.1")
Dim BREPName As String
BREPName = GetBrep(selFace.name)
Dim partDocument2 As PartDocument
Set partDocument2 = documents1.Item("2.CATPart")
Dim part2 As Part
Set part2 = partDocument2.Part
Dim hybridBodies2 As HybridBodies
Set hybridBodies2 = part2.HybridBodies
Dim reference1 As Reference
Set reference1 = part1.CreateReferenceFromBRepName(BREPName, assemble1)
Dim hybridShapeFactory2 As HybridShapeFactory
Set hybridShapeFactory2 = part2.HybridShapeFactory
Dim hybridShapeExtract2 As HybridShapeExtract
Set hybridShapeExtract2 = hybridShapeFactory2.AddNewExtract(reference1)
hybridShapeExtract2.PropagationType = 3
hybridShapeExtract2.ComplementaryExtract = False
hybridShapeExtract2.IsFederated = False
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies2.Item(1)
hybridBody1.AppendHybridShape hybridShapeExtract2
part2.Update
Dim reference2 As Reference
Set reference2 = part2.CreateReferenceFromObject(hybridShapeExtract2)
Dim hybridShapeSurfaceExplicit1 As HybridShapeSurfaceExplicit
Set hybridShapeSurfaceExplicit1 = hybridShapeFactory2.AddNewSurfaceDatum(reference2)
hybridShapeFactory2.DeleteObjectForDatum reference2
hybridBody1.AppendHybridShape hybridShapeSurfaceExplicit1
part2.InWorkObject = hybridShapeSurfaceExplicit1
part2.Update
End Sub
Public Function GetBrep(MyBRepName As String) As String
    MyBRepName = Replace(MyBRepName, "Selection_", "")
    MyBRepName = Left(MyBRepName, InStrRev(MyBRepName, "));"))
    MyBRepName = MyBRepName + ");WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR29)"
    GetBrep = MyBRepName
End Function
