Gerry45 :"When considered as a system, two lightly and solidly preloaded small-angled A/C brgs are in precisely the same thermally 'dodgy' situation as a deep groove brg installed with a negative clearance".
Now while it is certainly the case that two solidly preloaded bearings of any type are often in a "dodgy" situation, especially when the axial spacing is small, I do not agree with the contention that they are "precisely the same".
Kinematically, both arrangements obey the same rules - ie they are both really angular contact bearings. However, in terms of thermal runaway there is a difference between a bearing with an operating contact angle of say, 15 degrees, and one with an operating contact angle of close to 0 degrees, which is what you have in the case of a deep groove bearing which is lightly axially preloaded. If the radial preload increases, the contact angle decreases, and the bearing becomes stiffer, thus generating even more internal load and more heat. Once the contact angle becomes zero - and it will if the differential race temperature of the bearing gets high enough - the non linear radial stiffness v load is now in a somewhat different regime, where the mitigating effect of the contact angle v stiffness relation - although it admittedly has already become small - no longer exists at all, and the highly non-linear load v stiffness relationship inexoribly will lead to thermal runaway if the speed is high enough. It only takes a tiny change in radial clearance to go from a contact angle of 15 degrees to zero. With angular contact bearings, the bearing spacing also has a large effect on the situation, since axial expansion has the effect of relieving the preload. Once the contact angle has become zero, any beneficial effects of this are also lost. An exact analysis in any given case is obviously very complicated, but it can be done using FEA, although it is not straightforward - that's why nobody can usually give a definitive answer to the question of preload, and bearing manufacturers are undoubtedly conservative in many cases, or occasionally even just plain wrong in their recommendations. Ultimately, their business is selling bearings, not applying them. So your contention that "nothing will happen" in the case of this particular bearing may or may not be true. It depends on how things fall in the tolerance zones, and the exact nature of the housings etc. But there are good reasons why increased radial clearance is often specified for motor bearings, or indeed deep groove bearings in general, and I stand by my comments.
