Change color and layer
jopal
Automotive
Dec 5, 2007
121
Let me start by saying I know nothing about scripting. I copied this out of the portable script center.
I'm looking for this script to do exactly what it does, except I want it to pick everything visible on my screen, as opposed to the user selecting a single face. Can this be done?
Sub CATMain()
Dim partDocument1 As Documents
Set partDocument1 = Catia.ActiveDocument
Dim part1 As Parts
Set part1 = partDocument1.Part
Dim selection As Selection
Set selection = Catia.ActiveDocument.Selection
Dim hybridShapeFactory1 As HybridShapeFactory
Set hybridShapeFactory1 = part1.HybridShapeFactory
'~ setup filter
ReDim sFilter(0)
MsgBox "Select a Face"
sFilter(0) = "Face"
sStatus = Selection.SelectElement2(sFilter, "select a Face", False)
Dim Obj As VispProperties
Set Obj = Selection.VisProperties
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
'~ change layer
visProperties1.SetLayer catVisLayerBasic, 200
'~ change colour
Obj.SetRealColor 100,10,255,0
Obj.SetRealLineType 4,0
Obj.SetRealWidth 100,0
part1.Update
End Sub
You could fill the selection filter with the search function. Use the record macro button and setup the filter.
Language="VBSCRIPT"
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set selection1 = partDocument1.Selection
selection1.Search "((CATGmoSearch.Surface + CATGmoSearch.Curve) - CATGmoSearch.Plane),scr"
End Sub
Derek
Win XP64
21SP6/22SP4, 3DVIA Composer 2013X, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
 http://files.engineering.com/getfile.aspx?folder=26142aea-9881-4f38-9b4d-ae26f25d9867&file=Adv_Search.JPG
I'll still cant seem to get it all to work together....do i copy this new part of code into my previous code
