Change part attribute with journal when working in drawing (master model)
MartijnH
18
I'm trying to set part attributes with a VB journal. This all works fine when I'm in the part itself by using:
Code:
Dim workPart As Part = theSession.Parts.Work
and further on
Code:
workPart.SetUserAttribute(_attributeTitle1, -1, _attributeValue1, Update.Option.Later)
However, when I'm in the drawing of this part (master model), I cannot set the attribute of the actual part, it only sets the ?object? attribute of the drawing. Is there a method to set the part attribute? Or do I have to open the part and set the attributes there by using some code to open the part in the background?
You can set the part attributes of a component part file while working in the assembly. Open an assembly, start the journal recorder, select a component, edit properties -> attributes, make sure you change the "apply to" option to "part". The resulting recorded code should show you how to apply an attribute to the part.
You will need write access to the component part file so that you can save the changes you make to it.
download.aspx
www.nxjournaling.com
How do I get into this window? I'm working in NX 10.0, but I do not see the drop down menu in the window? I go to File > Properties and then I only see 'Displayed part properties'. Is there another way to reach the window you show?
UPDATE: Sorry, I found the menu by right clicking on the part in the assembly navigator
