Change Views 2
lapek
Aerospace
Aug 26, 2013
37
hi every body
im having a trouble tryng to get the isometric view. the code im using is the following.
under this code i change the view of the part and trying to get the isometric so the part can rotate from the isometric, but what is doing, is rotaring to isometric from the last rotate
my english is not so good, hope you can undestand me, thank you so much for your help.
Language="VBSCRIPT"
Sub CATMain()
For x = 0 to 1
For y = 0 to 1
For z = 0 to 1
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Set viewpoint3D1 = viewer3D1.Viewpoint3D
viewpoint3D1.PutSightDirection Array(z, y, z)
viewer3D1.Reframe
viewpoint3D1.PutSightDirection Array(0, 1, 0, 0, 0, 1)
viewer3D1.Reframe
Next
Next
Next
End Sub
ISO View
Code:
Sub CATMain()
Dim ActDoc As Document
Set ActDoc = CATIA.ActiveDocument
Dim camIsoView As Camera3D
Set camIsoView = ActDoc.Cameras.Item("* iso")
Dim objIsoViewPoint As Viewpoint3D
Set objIsoViewPoint = camIsoView.Viewpoint3D
Dim ActWin As Window
Set ActWin = CATIA.ActiveWindow
Dim ActViewer As Viewer3D
Set ActViewer = ActWin.ActiveViewer
ActViewer.Viewpoint3D = objIsoViewPoint
CATIA.StartCommand"Fit All In"
End Sub
Fernando
wow that great, thak you so much, for your answer
it works perfectly
Ferdinand,
Can you send the "step-by-step" direction for the script that you've just replied with?................
MZ7DYJ
