Civil Engineers;
Have any of you ever had an architect or any other profession change your drawing in the field and build to it without contacting you? If so, what kind of liability do I have on the project? I had a design that I completed for site grading, drainage and retaining walls and I was called out to the project to make some field recommendations. When I got there, I found that certain elements of the design were not built per the design and they have had problems with drainage because they did not implement my drawing. Come to find out, they wanted to cut some of the materials up front of the project and the architect marked out two catch basins, modified piping and changed several of the spot elevations. The contractor took that to go and did not question the architect or ask to bring the engineer out to verify the changes would work. They have had significant grading issues and water is not flowing right. I told the contractor that they did not build to what was designed and they are on their own. I contacted my lawyer and he said that they do not and cannot make a claim against me. Any similar situations out there????
RUNOFF
RUNOFF
