Changes to toolbars not being remembered
nickjb
35
If a I make a change to toolbar such as adding a new macro button it'll stay there for the day but when I log off and back on its gone. There are also no files in my recent items list. I'm thinking this might be a permissions issue as I'm not admin on this PC. Any ideas of a fix? SW 2007 SP5. Thanks, nick
Have your IT people give you admin (or at least read/write permission on the SW install files.
They claim to have given r/w permission on the solidworks folder. I wonder if this info is saved anywhere else.
I can't run the Copy Setting Wizard either, as it claims I need admin privilige.
You need write access to certain areas of the registry, particularly HKCU\Software\SolidWorks. You may also need write access to HKLM\Software\SolidWorks.
Eric
The info is saved in the Registry. I assumed having r/w permission on the SW install folder would allow changes to the SW portion.
I agree w/ EEnd. This is definitely a registry permissions thing. At the very least, you need access to HKCU\Software\SolidWorks.
Chris Gervais
Application Engineer
CSWP, CSWST
IT should be able to set the security of the Copy Settings Wizard to allow your usage.
