Changing line weight of text in dimensions NX 9.1
Twullf
196
I have searched the forums for this particular question and having not found anything I can only assume the answer is simple, blatant, and right in front of my nose.
I am working on a drawing created in NX 7.5. In which the text on the dimension was set to the medium weight. It was simple and the choices for line weight, light, medium and heavy, were available quickly and simply in the dialogue containing the other text options.
In NX 9.1 I have found the same dialogue, but not reference to the line weight. Under Drafting Preferences there is an option for Annotation but these options are not changing the text in the dimensions.
If someone could direct me to the location where these line weights can be altered I'd gratefully appreciate it.
If you're using TrueType fonts, then you change their 'weight' like you'd do in MS Word, you changing it to 'Bold'. However, you'll need to use a font that actually has both 'Regular' and 'Bold' options, such as Arial or Tahoma. To do this, select the dimensions of interest, press MB3 and select 'Settings...'. When the dialog opens, go to...
Text -> Dimension Text
...and in the same line where you set the color and font, there is an option for the style.
Of course if you prefer 'Bold' style for all of your dimensions then you should set this up in your Drafting Preferences before you start to place your dimensions, but if you're just interested is changing a few dimensions, then my procedure above will work for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I found it, the text style has to be set as a Unigraphics font, such as blockfont. Then the three familiar options of Thin Width, Normal, and Thick Width will become available. These options are apparently not available with the other font options.
