I can't find it in Y14.100 so I thought I'd ask here... Is it acceptable to change the scale on a projected or section view as long as you put the scale below the view name? I've never done this but a co-worker is asking me if he can do it on a section view (not a true projection in this instance)?
Also if the section view is on the same sheet as the parent view does the viewing direction have to match if it is not inline with the parent view? For example the view is to the bottom right of the section view can the section view be as if it were on the left (looking the opposite direction)?
