Changing Table Border Properties Causes Display Problems 1
TorsionalStress
234
Using AutoCAD 2006;
I created a table with the borderlines visible. I then modified the table by setting the borderlines to invisible. The procedure worked well. After editing existing text, the entire table disappeared.
Any suggestions how to make the table re-appear?
Any response will be greatly appreciated!
I figured out the problem to my own question! I think there's a bug in AutoCAD 2006. When making modifications to a table, it seems that AutoCAD moves the entities into the "Defpoints" layer. Activating the layer will display the disappeared table!
