Changing Text Anchor Position in a CATIA V6 Macro from Excel
RickyPhil
8
I have a macro where I am taking text from a spreadsheet and using it to create text in a CATIA V6 drawing. I can get the text in fine and I can change the font size, but I can't get the .AnchorPosition method to work. I get the error message, "The method AnchorPosition failed."
'Creates text
Set Text1 = CATIA.ActiveEditor.ActiveObject.Sheets.ActiveSheet.Views.ActiveView.Texts.Add(CStr(Range("A1").Value), 0, 0)
'Set font size
Text1.SetFontSize 0, 0, 0.15 * 25.4
'vvv The macro fails here vvv
Text1.anchorPosition = catBottomCenter
The above code (excecept with a string instead of a reference to a cell) works if I run it from the CATIA macro editor. Why is there a difference?
I am useing dots for non-integer numbers. Is there anything else you meant by reginal settings?
I think I have the right references in the Excel VBA. The macro creates the text and changes the font size. It just won't change the anchor position. Is there something the .AnchorPosition needs that the .SetFontSize doesn't?
I was able to make it work by using
Text1.anchorPosition = 6
instead of
