Changing the size of the font when printing from the port
AmazingSpiderman
Computer
May 14, 2004
Hi, I'm trying to change the size of the font when i send the information to the printer, my code is:
Code:
Open Puerto For Output As #fNum
    If Err = 0 Then
        Print #fNum, strCadena
        If bClosePortAfterPrint Then Close #fNum
    End If
where "Puerto" is the printer port, (LPT1, mapped to a network printer), and what i'm looking for is for a common command to tell the printer to make the font condensed.
I won't use the printer object, because it is to slow, even i know that with that object i can use Printer.fontSize=10, or something like that. Printing from the port is fast, and for my application, i need to print fast, so, if you know if exists a common command to tell every printer (there will be 44 dot-matrix printers, and maybe differents) or if there is another way to print fast and changing the size of the font, please let me know
Thanks in advance
Since you're printing directly to the port, you might sending the proper escape sequence to the printer that will cause the proper font setting change. You'll have to consult the manual for the printer to find out which escape sequences it will recogonize to perform the desired action.
