Hi all,
I am a mech engineer working on common plant/balance of plant systems for power plants. So your aux services like fire, demin water, comp air etc. We also do piping of gas and liquid fuels to a limited extent; typically from a terminal point at the site fence or from containers on site to a pump/filter at a gas turbine.
I joined my current company recently and am trying to create a foundation for pipe designs which is currently lacking. The current mind set is to take info from previous projects as oppose to having an established pipe design criteria. The work on previous projects is also not that great, mostly put together by junior engineers who didn't have real project exposure from what I understand. There aren't any real pipe design calcs, only hydraulics. The pipe spec being used is also in need of an update as it comes from the refinery industry (so more stringent than what we require) and is 30+ years old.
We are based in South Africa and work a lot with European clients and so are trying to steer towards European standards. The company's current pipe spec is all ASME, 'designed' to ASME B31.3 (and I guess ASME B31.8 for the gas).
My experience for aboveground steel piping design is solely based on ASME B31.3. I was also previously a Client's engineer and haven't done much pipe design in terms of stress analysis etc. My experience is more in layouts, integration and hydraulics. I have no experience in gas pipelines; thankfully, the company is looking to hire someone who does...
So, to my actual question. If the company moves to using European pipes and fittings (BS, EN, ISO etc.) how feasible is it to adopt EN 13480 (and associated codes) for our designs? Is it worth learning the EN codes or rather taking the time to qualify BS, EN, and SANS material, pipe and fittings to ASME B31.3/8?
I don't think anyone in the company looked at this before because our services are almost all low pressure, low temperature. But in my mind, you never know when something will go wrong for whatever reason and you need to be able to prove that there was some thought into your design. I don't want to get caught with my pants around my ankles saying "I used sched 10S pipe because the last project did".
I know this is a bit of a lame question as there are numerous factors involved but I need to make a decision urgently and am stuck. What I am hoping for is insights or comments from someone who was in similar shoes at some point.
Thanks,
Alastair
Thanks,
Alastair
