Check if product exist
iscariot
154
What would be the best way to check if a product exist in active model?
Would be ok like below, or there are better ways?
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "(Name=*test* & CATProductSearch.Product),all"
If selection1.Count >= 1 Then
	msgbox "Exist"
End If
End Sub
That is probably the simplest way.
But for large assemblies it can be really slow.
This can be faster, but you need to have the file name the same as PartNumber
Code:
Sub CATMain()
On Error Resume Next
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim productDocument1 As ProductDocument
Dim partDocument1 As PartDocument
Dim product1 As Product
Dim Selection1 As Selection
Set Selection1 = CATIA.ActiveDocument.Selection
Dim Name As String
Name = InputBox("Insert the document name")
If Name = "" Then
Exit Sub
End If
'Find a CATProduct
Set productDocument1 = documents1.Item(Name & ".CATProduct")
Set product1 = productDocument1.Product
'Find a CATPart
Set partDocument1 = documents1.Item(Name & ".CATPart")
Set product1 = partDocument1.GetItem(Name)
If product1.PartNumber = "" Then
MsgBox ("Product not found")
Else
MsgBox ("Found: " & product1.PartNumber)
End If
End Sub
Tiago Figueiredo
Tooling Engineer
Youtube channel:
