Check Valve Type Selection 1
JEP109
9
Is there a particular type of check valve that is preferred on the discharge side of an oil-flooded screw compressor. We are currently thinking that a "swing check" type would suffice but I am wanting to get a second opinion on the matter. Here is a short explanation on the setup of part of the system. There will be 2 oil-flooded screw compressors, one on-line and the other spare. The maximum discharge should be around 280 F at about 75 psia. On the other hand for the lubrication system we have "piston" check valves, any thoughts on this? Any feedback would be of great help, thanks!
Snorgy,
Thanks for the informational documents.
I was trying to see if anyone had any experience using a certain type of check valve for gas or liquid applications; and of any problems that have been encountered from using a particular type.
All check-valve types and constructions comes in different qualities and materials. Go for top quality with references. Same for compressur suppliers and compressors wih integrated check-valves. Some suppliers supply with top-grade valves, others with lower quality or types.
Generally:
Top-hinged swing check valves will more often than others give problems.
Swing check mid-section hinged (two half-moon formed parts bending back from center): better
Best: high quality disc check valves, with precisely guided disc. As example: Disco (Gestra) or competitors of equal quality.
