ahmed fouad
hi guys, please i need some help. i am going to install a pump baseplate. i need your advice which chemical anchor should i select ? the complete pump weight around 1 ton . 4 holes diameter 30mm/each . please tell me recommended size of anchor and the embedded length. also if you can assign the anchor model like HILTI.
THANK YOU ALL
THANK YOU ALL
