Sawsan311
Chemical
- Jun 21, 2019
- 303
Dear All,
Based on your field and design experience, for a system having multiple injection points fed from one single head injection pump, there are mainly two challenges experienced:
- flowmeters not able to measure or detect the low flow rates below 0.3 l/hr. What would be an optimum flowmeter to be selected for such a readibility issue.
- the control of the injection points might mandate installing Internal recycle control valves IRCD.. any experience on this technology?
What are other possible technologies available for mitigating the low flow rate readibility as well as the finetuning control.
Multihead pump design is the last resort since it will require changing existing design. A brownfield solution is much more needed.
