vjr0512
- Jun 6, 2011
- 114
In one of the Shell and Tube Heat Exchanger in the Polypropylene plant , the low temperature service calls for the LTCS material for the tubes . But the chloride content in the circulating cooling water is as high as 600 ppm. The temperature of cooling water outlet from the exchanger will be around 45 deg C.
The corrosion risk of the LTCS ( Low temperature Carbon steel) material for the above chloride contained Cooling water needs to be explored
If the corrosion risk is high then a suitable treatment system of the cooling water has to be thought off.
Thanks to clarify
Thanks to clarify
