Choke not working
RyreInc
205
I've constructed a circuit to charge a capacitor bank. A choke is in series with the 12V secondary of a transformer (pre-bridge rectifier) to limit current to about 5mA. The choke is 5.75H, 330ohm, which, at 60Hz, should have an impedance of about 2200ohm, right? 12V/2200ohm=5.4mA.
However, the 400uF of capacitors are charged in the first few cycles, instead of about 10s. Additionally, when I replace the caps with a 100k potentiometer, the current is definitely not limited to 5mA as resistance is decreased.
I measured both the inductance and resistance with meters, so I know the choke isn't defective.
Also, the active current limiter I use (2 BJTs, 2 resistors) as an alternative to the choke works as designed.
What is going on here??? Thanks for your help.
Is the choke in the DC path? Or AC?
Gunnar Englund
AC - straight off the transformer secondary, before rectifier. Rectifier is bridge-type, no center tap on transformer.
The math seems OK. Around 10 seconds to charge 400 uF to around 10 V.
A 12 V choke with a 330 ohms resistance seems to be a very small one. My bet is that the core saturates heavily. Use a "better" choke. One with a larger core.
Gunnar Englund
Does your choke data sheet show a rated current? I bet Skogsgurra is right, it's probably saturating.
Choke rating is 40mA, transformer rating is 950mA on secondary.
One thing I had previously dismissed was another bridge rectifier coming off the secondary, prior to the choke, which supplies a DC bus for control circuitry. Schematic is attached. (The zener diode is actually a 3-terminal voltage regulator; capacitor is after regulator)
 http://files.engineering.com/getfile.aspx?folder=9559535c-d102-4486-88af-0dafa0d59f75&file=cap_charging_schematic.bmp
I just realized how strange this circuit may appear. Perhaps it helps to know that this is a low voltage version of a pulsed power charging circuit; the high voltage equivalent we use charges 400u in about 10s (approximate), using a choke to restrict in-rush current.
Aha! The common ground, in combination with the first bridge rectifier, is the culprit. There is a current path I hadn't noticed before, that uses both rectifiers.
I can either lift the charging caps from ground, or change the first rectifier to a single diode.
Thanks for everyone's help!
I fail to spot that path. Can you describe it?
Gunnar Englund
On the negative half of the AC wave the current flows out the bottom of L2, then through D6, C1, and D3--not D7 like it "should". The common ground provides that path. The choke therefore only works only on the positive half of the AC wave.
Quite! So it is saturated from DC, all the same. Didn't see that.
The same is true for the positive half-wave.
Looks like you have to separate those two circits.
Gunnar Englund
Spotted the the parts in parallel = not needed, but worried about D9 as it is fed directly by (BR1)=D1 to D4 !
Reminds me of voltage multiplier circuit based on Bridge rectifiers isolated by caps in ac feed .
Sorry oops ..
( just spotted zener (D9) is really a regulator comment )
