MechEng176
- Jul 18, 2013
- 30
Hi Folks,
I'm working on a project where we have a natural gas line that needs to be purged using Nitrogen gas. Can't use a pig because of different size pipes and can't use a cycle purge because of balloons (for lack of a better word) we have in the line. I've attached a pic, the balloons are what separate the system that needs to be purged from the in-service system. They have a hold strength of 2psi, so if I pressure my system to over 2psi while purging they will move. For safety I'll try to go to 1.5psi max. I need to determine 2 things, 1 total venting capacity (keeping in mind the 1.5psi threshold), and 2 the Nitrogen flow rate required (these 2 should be equal right?).
We will pump Nitrogen from a tie-in point on the left side of the drawing and all the vents will be open. From my understanding for the choked flow calculations, P0 is the max pressure on the upstream side of the vents, so 1.5psig (or would it be the pressure at which N2 comes out of our Nitrogen pump? Because that is 6MPa, likewise I'd change density0 depending on if it's 1.5psi or 6MPa). I also added up all the area of the vents and made the calculator think it is just one big vent, will that affect anything?
One last thing, does Reynolds number come into play here?
Thanks!
Thanks!
