Hi guys!
I have a problem related to the foaming generation in NaOH 2% storage tank inside of small CIP system.
The alkal based solution is heated on 80oC, and after cleaning procedure, the foam is generated inside of the tank.
Has anyone encountered this kind of problem?
Do you have any recommendation where to start to come up with the solution?
Ian.
Ian.
