Yazan Atoum
I have a circular base plate with a opening as in the picture, I need to find the neutral axis location for bending on the plate to design for the maximum tension force per bolt, I believe most of the bolts will be in tension and a block of the steel plate will take compression.
can anyone help me or guide me to design such a Baseplate?
