hi,
I am designing a ground source heat pump system. I need to design a circulating piping system to disipate heat to the soil.my system is using the a very long U tube. the fluid will circulating from the surface of the ground to the underground (very deep, bout 50m). my question is it correct i am using bernoulli equation to calculate the overall system head to size the circulating pump? i ignore the minor losses since the pipeline is relatively long and i am using the HDPE pipe.
thank you very much!!
