EngDM
- Aug 10, 2021
- 673
Having to specify a full strength weld for an HSS to beam flange. Strictly when looking at the weld, is there something I'm missing to make sure that the CJP weld is developped into the beam flange? For the HSS itself I'm speccing a single bevel with backer bar for the HSS (1/2" fillet is required otherwise for full strength), but is there a minimum thickness of beam flange I need to worry about when trying to develop a CJP?
