bigbertha912
Aerospace
- Apr 14, 2016
- 13
I was asked to Analyze an aft Lavatory compartment that is being attached to the Aft Pressure bulkhead for a CL-650. This is my first time seeing it today and basically the lateral brackets (see attached photo) use the existing holes of the support structure to attach.
To me this is a major RED FLAG because i would imagine that F&DT is going to be a real bitch (I am not a DT expert). I also believe that in the 1G sitting, the upper lavatory compartments you can see in the photo will be pre-torquing the structure.
Any advice, or suggestions as to why this is okay or not okay? Analytically i can make it work, but that doesn't mean its a good idea, in my opinion.
I also attached the SRM which shows the angles/webs and stiffeners on the aft side of the pressure bulkhead.
