Clarification required for creep zone material using of pressure vessel / heat exchanger
sarawana
23
Hi Frds,
Design temp: 390 deg Celsius
Material : Sa 516 Gr70N
Can creep zone material be used for pressure vessels ?
is there code rule or standard for creep zone material required for FEA ?
saravana. E
Another way to ask your question would be to say:
" Is usage of SA 516 Gr 70N acceptable for pressure vessel design at 390 degree Celsius (734F) ? "
(This material is Carbon steel plate and one of the most commonly used materials for pressure components
Answer:.... Temperature limits for this material depend on your specific code of record ... It would not be permitted for Nuclear Power Applications, which have a maximum of 700F
Applicability and Maximum Temp. Limits
The ASTM A516 Gr.70 (ASME SA-516 Gr.70) plates are applicable for the construction of power boilers (ASME BPVC Section I), nuclear power plant components (ASME BPVC Section III Classes 2 & 3), pressure vessels (ASME BPVC Section VIII Divsion 1), and transport tanks (ASME BPVC Section XII). According to ASME BPVC Seciton II, the maximum temperature limits and its application for SA-516 Gr. 70 are listed respectively:
ASME Section I: 850°F
ASME Seciton III CL 2 & 3: 700°F
ASME Section VIII-1: 1000°F
ASME Section XII: 650°F
MJCronin
Sr. Process Engineer
Agree with MJCronin. Start with your Code of Construction.
thanks for ur reply MJCronin. it very useful.
Damn straight .... another point on the scoreboard for the Geezers .. !!!
MJCronin
